4U1UN United Nation
4U1UN United Nation
4U1UN –update We are receiving a lot of messages regarding the lack of 4U1UN
(United Nation Amateur Radio Club) activity on the bands. We will try to clear
some things about the current Club’s activities. Many of you do not know that
after the renovation of the UNHQ building in New York, the room dedicated to
the recreation area, on the 41st floor, in which the 4U1UN radio equipment was located,
was transferred to the special UN unit – Broadcast and Conference Support Section.
That room now is allocated to professional communications equipment.
This was the only room technically suitable to be used for installing our gear,
with easy access to the roof but after renovation it became off-limits for any other services,
except BCSS. https://dx-world.net/news-4u1un/
Re: 4U1UN United Nation
Info from 4U1UN, the United Nations Headquarters in New York City,
the station was on the air for about an hour on Wednesday, starting at 22Z.
The ops note “more good things to come in [the] future now that the remote setup is working correctly.”
4U1UN ---> Adrian, KO8SCA was active on 40 metres SSB from the United
Nations Amateur Radio Club for about one hour (23.00-00.00 UTC) on 27
November: "more good things to come in future, now that the remote setup is
working correctly". QSL via HB9BOU.
God Glim-ragende Morgen
Fik den i går aftes på 20 meter CW.
ATNO !
Det var egentlig længe efter "lukketid" på 20 meter 19:50 utc. Han var pænt over S-5
Først troede man at han kun kørte sine "Buddies" hjemme i USA.
Men så skal jeg hilse at sige han kørte EU.
Og det gjorde han så.
VY 73 og god jagt til stort set alle.
Hej Keneth
De må have fået gang i at kunne køre remote opp,
så de ikke skal ind i bygningen !
Det burde kunne give regelmæssige QRV tid.
Godt at de ikke er begrænset af tilgang til FN bygningen.
oh en rigtig god dag i dag dag - som Peter Plys ville have sagt!
LOTW confirmation af et helt nyt et !
4U1UN, 20 meter CW !
Så jeg kan kun anbefale at man kalder ham.
Han lytter bedre end man lige tror. Og bemærker han at der er EU der ude, så er han flink til at lytte ...
VY 73 til stort set alle, men specielt til dem der overholder Code Of Conduct.
Setup info:
4U1UN – UN New York
The 4U1UN ham group has gotten their remote operating setup going.
It is equipped with a K3 and ACOM amp on the 42nd floor of the building
with the operating position on the ground floor with a K3/0.
The connection from the one location to the other is by Ethernet and a pair of Remote Rig boxes.
jeg fik gaflet 4U1UN i en større pile-up lørdag eftermiddag. Der har før været pirater i gang i det call, men denne gang var den god nok. Det var så bånd #2 med dette sjældne call.
Ja det er bare at se at få den kørt på så mange bånd så muligt !
Jeg ved ikke hvad de har af Ant setop til HF det ser ud til at der er DXrpt ned til 80m ?
Kender heller ikke Remote reglerne for DXCC.
Jeg formoder at opp. fysisk skal være indefor UN's grund ?
Internet : Så kan man jo sidde et andet sted i USA m.m. den går nok ikke.
ikke noget problem heller ikke i forhold til DXCC programmet:
http://www.arrl.org/news/arrl-board-oka ... ting-rules
"It has always been permitted for a QSO to count for both stations, if either station was operated remotely from a control point within the same DXCC entity,” Sumner explained. “Now the location of the operator doesn’t matter; the operator could be on the far side of the Moon if he or she could figure out how to remotely control a station on land back on Earth from there.” Transmitter location continues to define a station’s location, and, for DXCC purposes, all transmitters and receivers must be located within a 500 meter diameter circle, excluding antenna"
Senest rettet af OU2X fre jan 03, 2020 23:01, rettet i alt 1 gang.
På conventionen i Visalia i April i år (2019) var det faktisk på tale, om man kunne sætte udstyr på fx 3Y0 (begge DXCC'er) og så sidde fra båden og køre QSO'er remote.
Man var ikke helt modstander af den løsning, så det kunne godt blive løsningen ud i fremtiden.
GODT NYTÅR
4U1UN ---> The 4U1UN re-activation project took over four years to complete.
James Sarte, K2QI and Adrian Ciuperca, KO8SCA are the key operators who
worked on the project, which is based on "a slick in-house remote concept":
the station is located at the 42nd floor of the UN Headquarters in New York
City, while the control head is located on the ground floor. They are the
recipients of the Yasme Excellence Award 2020, which Ria Jairam, N2RJ
(Director, ARRL Hudson Division) and Martti Laine, OH2BH (Director, Yasme
Foundation) will present to them at the UN Headquarters on 6 March. "This
ceremony will be topped with the first-ever FT8 QSO from 4U1UN - with its
inventor Joe Taylor, K1JT at the controls. First twenty-five QSOs will be
awarded by U.N special certificate signed by Joe". Following the ceremony
the group of K2QI, G6CBR, N2RJ, OH2BH, KO8SCA and VE7NY will activate 4U1UN
in the ARRL DX SSB Contest. QSL via HB9BOU and LoTW. [TNX OH2BH]
Det ser ud til at 4U1UN er aktive i disse dag !
find dem på DXcluster.
4U/UN - United Nations Headquarters
4U1UN began operating yesterday (Thursday) on 6 meters FT8 around 2040Z.
Activity was a warm up “getting ready for the 6M season”.
On 50 MHz the station is running about 100 watts into the BigIR (7-50 MHz).
In all, some 51 stations were worked through about 2345Z. QSL via HB9BOU.
4U1UN har været QRV de 27/5 6m-40m
NEWS UPDATE – Greetings from UNARC/4U1UN. As most are aware, UNHQ has been shut down for some time due to COVID-19. As a result, basic maintenance of equipment has been postponed until the building is reopened to staff. The Secretary General has implemented a multi-phased approach based on state and federal guidelines. As such, we hope to regain access in October or November. It’s at that time that maintenance activities will be scheduled with the appropriate departments in order to address pressing equipment failures. This includes repair to our Acom amplifier control module as well as the beacon antenna.
On other news, I’ve been testing and evaluating a Flex Radio Systems 6600M which was kindly loaned to us by our friends at Flex Radio. The Flex SDR system has proven more than capable of performing in our constrained operating environment, and is something as current club president, hope to implement into our station as soon as possible. Many thanks go to Flex Radio, especially, Matt Youngblood for his generosity and willingness to work with the United Nations Amateur Radio Club 4U1UN.
I’ll try to update you with more news as it’s made available to me by senior management and our administration.
Until then, be safe. Be well.
73, James K2QI.
