VP8PJ So Orkney
Re: VP8PJ So Orkney
Jeg kan se min 40 meter FT8 QSO den 25/2 ikke er i loggen. Jeg kørte dem samtidig med OZ3BEN og har tjekket decoder-loggen og fik positivt RR73 tilbage. Måske de har samme problem som tidligere expd. hvor QSO'er ikke logges korrekt når de kører flere spor...
PS: har kørt dem igen på 40 meter FT8 her til aften ;) så må vi se om den dukker op i online logcheck !
Re: VP8PJ So Orkney
Min høst indtil videre.
Jeg spyttede i kassen, da jeg var i Visalia i april, og så er det herligt, at LoTW allerede er bekræftet. De sidste kommer sikkert med næste upload fra VP8PJ.
Deres log search kører i øvrigt igen efter nedbrud/overbelastning i går aftes.
Re: VP8PJ So Orkney
Stort tillykke
Lige kørt dem på 17 meter SSB.
Også lige til Klubben (OZ7A) ved samme lejlighed
Re: VP8PJ So Orkney
VP8/o – South Orkney
The VP8PJ team updated their log Friday, noting the first QSO was
February 22 at 2356Z, the log at that point going through February 28 midday.
On Saturday morning they noted that a storm had come through but they had
expected the tough weather and were prepared.The antennas stayed up with
just some challenges to the larger verticals.The WeatherPort buildings performed
well, as expected. Gusts sometimes reached 80 kph or higher.Missing FT8 QSOs in
the log could not be fixed while on the island but M0URX will handle it once he gets
all the FT8 files.Departure was planned for March 6 with teardown starting March 4.
Time at sea will be five days.Arrival in port is March 11 and unloading the ship March 13.
The Braveheart then leaves Punta Arenas March 15.
Sunday afternoon the team was in good spirits continuing to make QSOs.
Heavy winds had returned and several verticals were damaged and repairs were being made.
51,000 QSOs were in the log.
Re: VP8PJ So Orkney
Tak for nyheden Boye. Noget kunne tyde på at de har en log problem, som nogle af de andreI DxExpds, når de kører multi-QSO FT8.
Re: VP8PJ So Orkney
Hej Flemming
Jeg ved ikke om de har et logproblem ?
Men de har haft upload problem via satelit !
Det kunne være den næste Exp skulle prøve via monnbounce !
Du har vel et kopi af din digitale QSO til at overbevise M0URX ?
Re: VP8PJ So Orkney
oz7c skrev: ons mar 04, 2020 16:02 Jeg ved ikke om de har et logproblem ?
Vejret har ikke vist sig fra den pæne side dernede. De kan kun uploade fra skibet og kun, når skibet er på visse positioner og tidspunkter af dagen. Der er vist kun lykkedes en gang, og de håber, at de kan uploade en gang mere, inden de sejler hjem.
Seneste nyt fra VP8PJ:
News Flash!!!!!
After consultation with the Braveheart skipper this morning, we will now leave Signy Island on Saturday March 7th.
Improving weather and sea conditions are more favorable for a later departure.
We will extend our on air operations by another full day. We will now operate through most of Thursday March 5th.
Please disregard the earlier notice on the end of operations being later today.
VP8PJ Team
Sidste udkald er vist torsdag d. 5. marts - for denne omgang.
Re: VP8PJ So Orkney
Ja, de har selv skrevet at de har et FT8 logproblem... om det er sammenfaldne med mine QSO'er ved jeg jo reelt ikke før de kigger på det. Men 40 meter QSO'en kørte jeg igen ;) BTW: De har formodenlig den fulde log selv, de fleste programmer logger al decodning i en separat "debug fil". Men de skal manuel tjekke, hvilket er tidskrævende.
Jeg afventer med stor spænding at loggen bliver uploaded !
Ja det er vist en ordenlig rusketur med høje vindstyrker og planen var QRT den 4, som nu er udsat til den 6-7.
Vi krydser fingre for dem !
Re: VP8PJ So Orkney
Hej Flemming ...
Her ventes ligeledes spændt på deres næste LOG Update. Det har formodentlig givet en hel del unødvendig QRM fra bl.a gengangere, som bare lige ville være sikker for en sikkerheds skyld ....
VP8PJ- 4.3.2020.JPG (18.32 KiB) Vist 18834 gange
Re: VP8PJ So Orkney
Hej Palle
Nice work Palle, og equinox kan altså noget, vi er jo i solpletminimum og så kom der en 12m QSO i loggen ;) Hvad tid kørte du dem på 12 meter ?
Re: VP8PJ So Orkney
Hej Flemming ..
De var aktive og hørbare i et kort vindue imellem 16:30 --> 17:00 UTC. De er pt. aktive igen på 12M og OZ1LWT har netop kørt ham via CW.
Held og lykke den sidste dag, idag.
Re: VP8PJ So Orkney
seneste nyt (tror jeg) https://dxnews.com/vp8-vp8dxu/
We are pleased to report that we are nearing 70,000 QSOs in the log.
Our plan is to remain active on the bands throughout the day. We anticipate ending radio operations and going QRT at or near 23:59 UTC.
Re: VP8PJ So Orkney
Hej Palle
Lidt SunSet- boost kan jeg se på tidspunktet ... en klassiker ;) Hvad bruger du af antenne på 12 meter ?
PS: Uret på RDE Forum er vist allederede skiftet til sommer tid (GMT+2) - hi
Re: VP8PJ So Orkney
Hej Flemming ...
Det kunne sagtens være noget i den retning ... Ifølge VOACAP passer det nu også meget godt.
Mit simple setup er for tiden en ICOM 7610 , 3 ELM SteppIR, BIG SteppIR , 43 Foot Multiband vertikal (MFJ 2990) samt et MEGET omtalt ACOM 2100 PA-Trin ca. 1KW, idet jeg "kun" har ét aktivt callsign .... På RX siden benytter jeg 4 stk Beverage hvoraf de 3 er forkortet til ca. 40M og den sidste er ude i fuld 160M længde.
Re: VP8PJ So Orkney
... ja?
Der skal nok lidt mere til end 100 watt og en W3DZZ i græsnavle højde der?
Måske en stor Kystradiostations antenne, med monster store effekter, kan gøre underværker?
God jagt til dem der ikke har South Orkney bekræftet endnu.
Og knæk & bræk til den seriøse DX'er, der bruger mere end 15 minutter på dette fantastiske DX-projekt
VY 73 til stort set næsten, men desværre ikke alle
