Z6 Kosevo
Z6 Kosevo
Der har i DXnews været bragt dette:
Z6 Prefix: A More Accurate Characterization
By N7NG, Wayne A. Mills
______________________________________________________________________
The ARRL recently reported that the ITU Secretary General, Houlin
Zhou, stated "the ITU has not allocated call sign series Z6 to any of
its member states." http://www.arrl.org/news/assigning-kosovo-z6-call-
signs-unauthorized-and-illegal-itu-secretary-general-says
"Consequently, the utilization of call signs series Z6 by any entity
without a formal allocation and consent of the ITU represents an
unauthorized and illegal usage of this international numbering
resource." - Houlin Zhou
A highly professional legal opinion states that "Kosovo is not an ITU
member state and is therefore not eligible to receive a call sign
block allocation from the ITU. [The Kosovo] administration has been
blocked from joining the ITU and becoming a party to the Radio
Regulations. Therefore the characterization of [the] use of the radio
callsign prefix Z6 to identify [radio transmissions in Kosovo] as
"illegal" is without foundation in international law. At this time the
Republic of Kosovo is not a signatory to the [ITU] treaty, although it
would be so if objections by others were removed".
Another opinion can be found at
http://www.amateurradio.eu/2018/06/25/i ... cal-arena/
There is little that I can - or should - add to the above. In
attempting to find a useful characterization for Kosovo's fit into the
DXCC program I looked at sovereignty. In fact, I did considerable
research on the topic. Sovereignty is difficult to define. As one
ITU/Amateur Radio expert put it: The concept of sovereignty is
"squishy". Simply put, it is difficult to define.
There are several generally accepted criteria for sovereignty, but
IMO, they are all somewhat vague, and not universally accepted. The
ARRL, recognizing this, chose to rely on a third party - The United
States Department of State - to simplify matters. For a number of
reasons - and IMO - this solution is more than adequate for ARRL's
purposes.
Z6 prefix er ikke tildelt af ITU ?
https://www.itu.int/en/ITU-R/terrestria ... eries.aspx
Der er jo andre prefix der heller ikke er man er godkendt af ARRL DXCC
1S Sprately !
Re: Z6 Kosevo
... og alle husker vel "balladen" om Syd-sudan, ikke?
Der gik lang tid inden de fik tildelt Z8
Re: Z6 Kosevo
Mon ikke det er Serbien YU der har en del at sige i denne afære. Måske søget om Z6 prefix ?
Da kosovo havde YU8 prefix var der jo lige pluselig alle i YU der brugte YU8 til chikane af Kosevo !
Det var sidst det vist var ve at blive godkendt til DXCC.
Mon ikke ITU lige så godt kan teldele dem Z6 ?
Det vil ikke være smart at give det til andre, det vil bare være at sætte
ITU i dårligt lys !
Re: Z6 Kosevo
Der er gang i Z6
Det ser ud til at det går strygende mine qso'er der er et par dage gammel
med Z68M er nu på LOTW ! eneste krav var OQRS via direkte 4$ for alle QSO'er
Så der kommer kort nå post norden gider besøge min postkasse om 1-2 uger ?
CFM DXCC 340/339/340 MX/CW/PHONE
Det er P5 på cw der mangler det bliver nok ikke forløbig !
Re: Z6 Kosevo
oz7c skrev: fre jul 27, 2018 8:52 Det er P5 på cw der mangler det bliver nok ikke forløbig !
Boye hvis du skaffer tilladelse til, at jeg kan være radioamatør i P5 inkl. papirer som ARRL kan godkende til DXCC samt at sikre mit ophold i landet samt sikker ind-og udrejse, så tager jeg gerne af sted.
Det kunne give RIGTIG mange $$$$ i kassen for direkte QSL efter sådan en tur.
Re: Z6 Kosevo
Hej jørgen
P5 opp det ville være en nyhed der ville noget !
Vi må nok afvendte at USA tager sig sammen !
Der kommer mere Z6 har modtaget dette fra DXnews:
Kosovo and Foxes
Martti, OH2BH, Fehmi, Z62FB and Driton, Z61DX will give the FT8 Fox
mode a final push this weekend on multiple bands. The 17M will be
added to their offering. They may be found also in the IOTA contest
even if Kosovo is land-locked with no islands to boot.
Today they are clearing a shipment of Amateur Radio equipment and
material for the local Association, SHRAK, and their new hams,
provided by Yasme Foundation.
Jeg kører ikke selv FT8 så det bliver ikke mig der laver QRM !
Re: Z6 Kosevo
oz7c skrev: fre jul 27, 2018 20:35 Vi må nok afvendte at USA tager sig sammen !
Det er ikke meget arbejde, du vil gøre for at få den sidste.
