8 Band EME DX expedition from Botswana, A21EME
Så er det med at få gjort antenner og grej klart:
From 20 october - 29 october 2019 is A21EME in KG25wk QRV,
From 20 october - 25 october 2019 6m, 2m, 70cm EME. Mode JT65 and CW.
From 20 october - 29 october 2019 23, 13, 9, 6 and 3cm. Mode JT65 and CW
Group members:
Lins PA3CMC
John ZS6JON
Chris PA2CHR
Paul ZS6NK
Andrew ZS6AVH
Bernie ZS4TX
Sam HB9COG
Dan HB9CRQ
Station:
6m 6M8GJ
2m 2 x 12el X pole design I3DLI
70cm 2 x 28 el. m2
23, 13, 9, 6 and 3cm 1.5m dish 1x2mm mesh, automatic az and el control
1296: 100W at feed, circular, preamp at horn
23xx: 80W at feed, circular, preamp at horn
3400: 80W at feed, circular, preamp at horn
5760: 80W at feed, circular, preamp at horn
10xxx: 50W at feed, v-pol, preamp at horn
Any donations are welcome.
Paypal info@pa3cmc.nl
Bank IBAN NL58INGB0006770934
BIC INGBNL2A
QSL direct or via buro
Direct wit SAE and €2 or $2, if not enough postage QSL send back via buro.
PSE NO IRC's NOT Accepted here. All sponsors automatically recieve QSL direct.
L Berben
Simonshoek 2
5768 CS Meijel
Netherlands
More will follow on my website www.pa3cmc.nl
73 Lins PA3CMC
2m EME DXCC #30
EA5/PA3CMC ZS/PA3CMC Z21CMC 3DA0LB
Member of Z21EME EME DX Expedition 2014
Member of HV0A EME DX Expedition 2015
Member of 3DA0MB EME DX Expedition 2017
Member of www.mmmonvhf.de
www.pa3cmc.nl
Re: 8 Band EME DX expedition from Botswana, A21EME
hvis man nu skulle i gang med EME, hvor finder man så lidt information for en absolut nybegynder?
Jeg har antenner til og med 23 cm, og jeg håber at finde tiden til at sætte mast #2 op i løbet af 2018.
En god kilde med information om næsten alt vedrørende EME er K1JT, Joe Taylor:
https://physics.princeton.edu/pulsar/k1jt/refs.html
Med hensyn til A21EME, så vil forbindelse med dem på mikrobølgebåndene nok kræve en parabol af en vis størrelse, da de kun kører med en 1,5 m parabol. Fra 23 til 6 cm kører de med cirkulær polaritet, som er en fordel da polariteten hen over et Moon pass varierer op til 90 grader (spatial offset). De kører lineært lodret polariseret på 3 cm, så da må vi afvente de tidspunkter, hvor der er mindst tab på grund af forskellen i polaritet.
