RX ant low band
: fre feb 26, 2021 18:21
Der kører en discution omkring RX ant på Topband refectoren
For dem der interserer sig for disse emner vil jeg anbefale subcribe til topband
Link nede i bunden
Her er nogle af de indlæg der har været:
Hi guys
I would like to share some papers from my good friend (SK) Dr Dallas was a great experimental guy that loved Mathematic and AM DXing,. Dr Dallas with a strong personality and seniority some times was hard to follow and some time the result of tests were not as planned, like the multi turn flags.
Dr Dallas interest was on MF 500KHz to 1600 MHz and some results are not the same on 160 or 80m. I can send the original paper attached if requested.
Flag Theory
Dallas Lankford, 1/31/09, rev. 9/9/09
The derivation which follows is a variation of Belrose's classical derivation for ferrite rod loop antennas,
“Ferromagnetic Loop Aerials,” Wireless Engineer, February 1955, 41– 46.
Some people who have not actually compared the signal output of a flag antenna to other small antennas have
expressed their opinions to me that the signal output of a flag antenna has great attenuation compared to those
other small antennas, such as loops and passive verticals. Their opinions are wrong. One should never express
opinions which are based, say, on computer simulations alone, without actual measurements. The development
below is based on physics (including Maxwell's equations), mathematics, and measurements.
Measurements have confirmed that the flag signal to noise formula derived below is approximately correct
despite EZNEC simulations to the contrary. For example, EZNEC simulation of a 15' square loop at 1 MHz
predicts its gain is about +4 dbi, while on the other hand EZNEC simulation of a 15' square flag at 1 MHz
predicts its gain is about –46 dBi. But if you construct such a loop and such a flag and observe the signal
strengths produced by them for daytime groundwave MW signals, you will find that the maximum loop and flag
signal outputs are about equal. Although somewhat more difficult to judge, the nighttime skywave MW signals
are also about equal.
Also, the signal to noise ratio formula below for flag arrays has been verified by man made noise measurements
in the 160 meter band using a smaller flag array than the MW flag array discussed below. Several years ago a
similar signal to noise ratio formula for small untuned (broadband) loop antennas was verified at the low end of
the NDB band.
The signal voltage es in volts for a one turn loop of area A in meters and a signal of wavelength λ for a given
radio wave is
es = [2πA Es /λ] COS(θ)
where Es is the signal strength in volts per meter and θ is the angle between the plane of the loop and the radio
wave. It is well known that if an omnidirectional antenna, say a short whip, is attached to one of the output
terminals of the loop and the phase difference between the loop and vertical and the amplitude of the whip are
adjusted to produce a cardioid patten, then this occurs for a phase difference of 90 degrees and a whip amplitude
equal to the amplitude of the loop, and the signal voltage in this case is
es = [2πA Es /λ] [1 + COS(θ)] .
Notice that the maximum signal voltage of the cardioid antenna is twice the maximum signal voltage of the loop
(or vertical) alone. A flag antenna is a one turn loop antenna with a resistance of several hundred ohms inserted
at some point into the one turn. With a rectangular turn, with the resistor appropriately placed and adjusted for
the appropriate value, the flag antenna will generate a cardioid pattern. The exact mechanism by which this
occurs is not given here. Nevertheless, based on measurements, the flag antenna signal voltage is approximately
the same as the cardioid pattern given above. The difference between an actual flag and the cardioid pattern
above is that an actual flag pattern is not a perfect cardioid for some cardioid geometries and resistors. In
general a flag pattern will be
es = [2πA Es /λ] [1 + kCOS(θ)]
where k is a constant less than or equal to 1, say 0.90 for a “poor” flag, to 0.99 or more for a “good” flag. This
has virtually no effect of the maximum signal pickup, but can have a significant effect on the null depth.
1
The thermal output noise voltage en for a loop is
en = √(4kTRB)
where k (1.37 x 10^–23) is Boltzman's constant, T is the absolute temperature (taken as 290), (Belrose said:) R is
the resistive component of the input impedance, (but also according to Belrose:) R = 2πfL where L is the loop
inductance in Henrys, and B is the receiver bandwidth in Hertz. When the loop is rotated so that the signal is
maximum, the signal to noise ratio is
SNR = es/en = [2πA Es /λ]/√(4kTRB) = [66Af/√(LB)]Es .
The point of this formula is that the sensitivity of small loop antennas can be limited by internally generated
thermal noise which is a characteristic of the loop itself. Even amplifying the loop output with the lowest noise
figure preamp available may not improve the loop sensitivity if man made noise drops low enough.
Notice that on the one hand Belrose said R is the resistive component of the input impedance, but on the other
hand R = 2πL. Well never mind. Based on personal on hands experience building small loops, I believe R =
2πL is approximately correct. What I believe Belrose meant is that R is the magnitude of the output impedance.
For a flag antenna rotated so the the signal is maximum, the signal to noise ratio is
SNR = es/en = 2[2πA Es/λ]/√(4kT√((2πfL)^2 + (Rflag)^2)B) = [322Af/√(√((2πfL)^2 + (Rflag)^2)B)]Es .
Now let us calculate a SNR. Consider a flag 15' by 15' with inductance 24 μH at 1.0 MHz with 910 ohm flag
resistor, and a bandwidth of B = 6000 Hz. Then A = 20.9 square meters and SNR = 2.86x10^6 Es . If Es is in
microvolts, the the SNR formula becomes
SNR = 2.9 Es .
Any phased array has loss (or in some cases gain) due to the phase difference of the signals from the two
antennas which are combined to produce the nulls. This loss (or gain) depends on (1) the separation of the two
antennas, (2) the arrival angle of the signal, and (3) the method used to phase the two flags. Let φ be the phase
difference for a signal arriving at the two antennas. It can be shown by integrating the difference of the squares
of the respective cosine functions that the amplitude A of the RMS voltage output of the combiner given RMS
inputs with amplitudes e is equal to to e√(1 – COS( φ)) where e is the amplitude of the RMS signal, in other
words,
A= 1
2π∫
0
2 e2cost−costφ2dt=e21−cosφ
The gain or loss for a signal passing through the combiner due to their phase difference is thus √(1 – COS( φ)).
Let us consider the best case, when the signal arrives from the maximum direction. For a spacing s between the
centers of the flags, if the arrival angle is α, then the distance d which determines the phase difference between
the two signals is d = s COS(α). If s is given in feet, then the conversion of d to meters is d = s COS(α)/3.28.
The reciprocal of the velocity of light 1/2.99x10^8 = 3.34 nS/meter is the time delay per meter of light (or radio
waves) in air. So the phase difference of the two signals above in terms of time is T = 3.34 s COS(α)/3.28 nS
when s is in meters. The phase difference in degrees is thus φ = 0.36Tf = 0.36 f x 3.34 s COS(α)/3.28 where f is
the frequency of the signals in MHz. If additional delay T' is added (phase shift to generate nulls or to adjust the
reception pattern), then the phase difference is φ = 0.36(T + T')f = 0.36f(T' + 3.34 s COS(α)/3.28) . If the
additional delay is implemented with a length of coax L feet long with velocity factor VF, then the phase delay is
φ = 0.37f(L/VF + s COS(α))
where f is the frequency of the signal in MHz, s is in feet, L is in feet, and α is the arrival angle.
2
In the case of the flag array above in the maximum direction there are two sources of delay, namely 60.6 feet of
coax with velocity factor 0.70, and 100 feet of spacing between the two flag antennas. The phase delay at 1.0
MHz for a 30 degree arrival angle is thus
φ = 0.37 x 1.0 x (60.6/0.70 + 100 COS(30)) = 64.1 degrees.
Thus the signal loss in the maximum direction at 30 degree arrival angle due to spacing and the phaser is
√(1 – COS( 64.1)) = 0.75 or 20 log(0.75/2) = –8.5 dB.
Now comes the interesting part. What happens when we phase the WF array with dimensions and spacing given
above? The flag thermal noise output doubles (two flags), and the flag signal output decreases (due to spacing
and phaser loss), so the SNR is degraded by 14.5 dB to
SNR = 0.55 Es .
So a signal of 1.8 microvolts per meter is equivalent to the thermal noise floor of the flag array.
On some occasions, when man made noise drops to very low levels at my location, it appeared to fall below the
thermal noise floor of the WF array. By that I mean that the characteristic “sharp” man made noise changed
character to a “smooth” hiss. To determine whether this was the case, I measured the man made noise at my
location for one of these low noise events at 1.83 MHz.
To measure man made noise at my location I converted one of the flags of my MW flag array to a loop. The
loop was 15' by 15', or 20.9 square meters. I used my R-390A whose carrier (S) meter indicates signals as low
as –127 dBm. The meter indication was 4 dB. Then I used an HP-8540B signal generator to determine the dBm
value for 4 dB on the R-390A meter. It was –122 dBm. Now the fun begins. The RDF of a loop for an arrival
angle of 20 degrees (the estimated wave tilt of
man made noise at 1.83 MHz) was 4 dB. So now
man made noise after factoring out the loop
directionality was estimated as –118 dBm. Field
strength is open circuit voltage equivalent, which
gives us –112 dBm. I measured MM noise on the
R-390A with a 6 kHz BW. The conversion to
500 Hz is –10 log(6000/500) = –10.8, which
gives us –122.8 or –123 dBm. The conversion to
500 Hz was necessary in order to be consistent
with the SNR above which was calculated for a
500 Hz BW. The loop equation is es = 2πAEs
/lambda = 0.41 Es, and 20 log(0.41) = –7.7,
rounded off to - 8, so we have -115 dBm, or 0.40
microvolts per meter for my lowest levels of man
made noise at 1.83 MHz in a 500 Hz bandwidth.
This seemed impossibly low to me until I came
across the the ITU graph at right. Man made
noise at quiet rural locations may be even lower
than 0.40 microvolts per meter at 1.83 MHz. But what about the MW band? From the CCIR Report 322 we
find that the man made noise field strength on the average is about 10 dB higher at 1.0 MHz than 1.83 MHz,
which would make it 1.26 microvolts per meter at 1.0 MHz. Another 4 dB is added because of impedance
mismatch between the R-390A and the loop, which brings man made noise up to 2.0 microvolts per meter at 1.0
MHz. The RDF of one of these flags is about 7 dB, which lowers the man made noise to 0.89 microvolts per
meter. Observations in the 160 meter band do not seem to agree exactly with this analysis because flag thermal
noise has never been heard on the MW flag array. But it would not surprise me at all if the flag array thermal
noise floor were only a few dB below received minimum daytime man made noise and that measurement error
(for example, calibration of my HP 8640B) accounts for the difference between measurement and theory. Also,
observations with a flag array having flag areas half the size of the MW flag elements in the 160 meter band do
confirm the signal to noise ratio formula; in this case, flag thermal noise does dominate minimum daytime man
made noise at my location (0.40 microvolts per meter field strength measured as described above.
Hi guys
This is a collection of paper I was able to put together, please it is a working in progress and new entries are welcome. My eye is not doing well and it is hard for me to type, so this is a copy and paste.
1919
March 5, 1919, Roy A. Weagant, Chief Engineer of the Marconi Wireless Telegraph Co. of America, delivered a paper describing in detail his apparatus for the elimination of the great bug-bear of transoceanic wireless communication --static interference. >>
http://infoage.org/html/wa-1919-04-p11.html
1938
Harold Beverage invented wide band receiver antenna, loaded loop. The present invention relates to short wave antennas and, more particularly, to antennas for receiving horizontally polarized waves over a wide band of frequencies. An object of the present invention is to enable the reception of horizontally polarized signals over a wide band of frequencies such-as is at present used in television.
https://docs.google.com/viewer?url=pate ... 247743.pdf
1940.
Nearly all the newly re-invented compact receive antennas derive from the terminated loop, the earliest reference was in an appallingly mimeographed prewar training manual of W3EEE Dad‘s
1973
COMMUNICATIONS 74 CONFERENCE BRIGHTON Wednesday, June 5 1974 —Session 5 Equipment Design Paper 5.3: Loop Antennas for HF Reception Contributed by: B.S. Collins, C & S Antennas Ltd.,
1995
JF1DMQ wrote an earlier article about the Flag antenna in November 1995 in a Japanese magazine. His was only 3.3 feet by 16.4 feet long (1 by 5 m). K6SE's 160m optimized versions are 14 by 29 feet (4.3 by 8.8m).
1995
"Is This EWE for You?" (QST February, 1995, p.31) and "More EWES for You",
QST January, 1996, p. 32) both by WA2WVL.
1996
The Pennant was originated by EA3VYand optimized for 160 meters by K6SE, who first wrote about them on the Top Band Reflector in 1998
1997
The K9AYTerminated Loop—A Compact, Directional Receiving Antenna By Gary Breed, K9AY
1998
W7IUV rotatable Flag and preamplifier >> http://w7iuv.com/
2000
QST Magazine, July 2000, page 34 for K6SE's classic article:
"Flags, Pennants, and Other Ground-Independent Low-Band Receiving Antennas" ...
2003
NX4D developed the first dual flag vertical array
2006
N4IS developed the BIG flag vertical array
2008
N4IS developed the Horizontal flag array
2009
Dr Dallas Lankford, wrote the Flag Theory and design the Quad Flag Array >> Dallas Files The Dallas Files are now found here: http://groups.yahoo.com/group/thedallasfiles2
2009
AA7JV George Wallner developed the DHDL (TX3A) >> http://tx3a.com/docs/TX3A_DOUBLE_HALF_DELTA_LOOP.ZIP
2009
DOUBLING the Double Half-Delta Loop Receiving Antenna
by Pierluigi“Luis” MansuttiIV3PRK >>
http://www.iv3prk.it/user/image/..-rxant.prk_tx3a.pdf
Please add new papers
73’s
JC
N4IS
JC,
Thanks for posting this.
That first link doesn't work, it comes up article not found. The W7IUV link is down also.
The Dallas Lankford files have been removed (by request) and that Yahoo link is not valid any longer, but there are complete sets of his papers floating around on the Internet still.
Just wanted to mention that.
Rick Kunath, K9AO
Here the procedure I used to measure my receiver equivalent bandwith to
calculate NF.
https://www.owenduffy.net/measurement/e ... reIfBw.htm
SpecrunLab is also a very good tool to measure EBW
https://www.owenduffy.net/measurement/e ... eIfBw2.htm
JC
N4IS
73's
http://www.contesting.com/_topband - Topband Reflector
Re: RX ant low band
: fre feb 26, 2021 19:37
Her er næste afsnit !
Det er N4IS der har meget erfaring med denne ant type
Her er en link til hans web page
https://www.kkn.net/dayton2011/N4ISWallerFlag.pdf
Her er det sidste
Hi Guys
This concept is important and very confusing, so sorry for being a broken
record. I’ll keep it very simple to understand.
The Flag antenna and its variances, EWE, pennant WF SAL DHL and others
nice names are basic the same and like this:
Two wires in U shape, one upside down and one normal , with two openings.
_____________
Open1 open 2
The way to see it is like two vertical dipoles and two horizontal phasing
lines. On the opening one we terminate with a RESISTOR, the valuer of the
resistor is not important but for this exercise lets use 1000 ohms. Or two
vertical vectors and two horizontal vectors.
O the opening one we will connect the feed line. That’s the Flag, two
vertical in phase, Because the vertical dipole is too small it reflects the
current to the other dipole., and vice versa. The side one with the resistor
the current will be dissipated on the resistor,, but on the open 2 the
current can me connected to the feed line.
At this point the system could be balanced and the reactive component will
be very low if we pick for the feed line the same impedance of the load,
1000 ohms. You can simulate that on EZNEC and you will find it very
broadband.
The 1000 ohms feed line is part or the receiving system and not part of the
antenna, so any loss will represent “noise” and will be add to the noise
figure of the receiver,. It you use a 9:1 transformer, the feed line could
be close to 100 ohm, It is simple to use a twisted pair close to 100 ohm
impedance , like twisted pair form a Ethernet cable will provide very low
SWR and no common mode noise, no shield is necessary.
The losses on the transformer and the feed like is part of the receiver
input circuit and not part of the antenna. The power noise is independent of
the valor of the resistor and the noise temperature on the vertical dipole
“open 2” is the same as any dipole. Please keep it simple and G/T of a
dipole is very well know. It is just two phased very small dipoles.
Based on the above is very simple to understand the EWE, just replace the
normal U by the antenna reflected by the ground (like a mirror). Cut all by
½, so the resistor will be 500 ohms and the impedance easy to match 50 ohms
using a 9:1 BALUN
Also the K9AY is easy to understand, just think the ground as a 1000 ohms
transmission line, and you can move the resistor close to the BALUN, like
the EWE.
As any antenna, the thermal noise is the limit of the amplifier to produce
any gain, if you want to work over 300 DXCC ( confirmed ) on 160m, make the
flag 24”x 12” and use it, spend time on that chair , tunning the radio and
enjoying 160, it is not easy and that’s why we love it.
JC
N4IS
I would like to share some of my experience with small flags'.
The directivity is the same for a large chance in frequency but the gain increase with size.
As a reference NX4D started with a single flag 14' high 7' wide , using a 20 db gain preamp. Is was good enough to work 150
countries on 160m, for 80m you can reduce the size by 1/2 and expect the same results. Basically it is a flag like k9AY, EWE, pennant and others
loaded loop, one resistor and one transformer.
The RDF is a limitation and Doug phased two loops 14x7 spaced 16ft for a
total boom of 30FT. all fiberglass, and an isolated mast from the tower and,
not portable, I called small Waller Flag. The two 14x7 flag was good enough
to work over 200 countries from a 1/5 acre lot in a subdivision with a lot of
noise form neighbors. Detuning the TX antenna was a must for good
performance, including working JT1CO direct path over the North pole on
160m.
But the gain of the antenna was a limitation on 160m, and he built a Monster
WF to work 311 DXCC on 160.
2 db NF and 20 db gain is all you need for a vertical flag or dual flag like the WF(Waller Flag, from Doug Waller, NX4D)
33db gain is too much for a flag or WF vertical, it is good for a flag or a
WF horizontal, and at least 75 ft above ground.
Here is important to remember if you S meter is moving you have too much
gain, I match my preamp gain for s0 on band noise during the day. There is a
lot of signals bellow S0. Keep the gain at minimum.
To reduce common mode noise a twisted pair 100ohms feed like helps a lot.
Measure noise figure at 1.8 MHz is a great task and care, with a good signal
generator and good sound card, you can take one measure in 2 hours of work
for -+ 0.1 db accuracy.
Doug me and Dr Dallas did a long experiment to measure that and a small flag
14'x7', was not thermal noise limited for DX use on low babnds.
At a very quiet rural area with -125 dbm noise floor during the day. For
reference , my city lot average -85 dbm during the day and the best I ever
measured was -95db on those winter Sunday Mornings with light rain.
The Dallas files is not available, Dr Dallas is SK but I have some paper I
can share here.
So a small loop is not thermal noise limited on 160m, and works very well on
80, 60 40 and 30m. some big contest station using a HWF reported problems of
power line noise on 20m and the HWF saved them transmitting on the yagis and
receiving on the HWF. On 80 and 40m the HWF is comparable only to a 4
elements full size yagi. ( same directivity, but vertical noise canceling)
The easy way and accurate is to use FSM easy to do in 3 steps , here >>>
https://www.owenduffy.net/software/fsm/index.htm
FSM (for Field Strength Meter) is a software application that extends a
conventional SSB receiver to allow measurement and calculation of field
strength of radio signals or interference. FSM is a software implementation
of a development of the technique described by Ed Hare of the ARRL in
"Manual Testing of Field-Strength Levels Using Conventional Receivers" dated
August 2004 .
You need a good sound car and a 50 ohm shielded load, like an N or BNC
connector 50 ohm termination.
Regards
JC
N4IS
Re: RX ant low band
: lør feb 27, 2021 12:59
Re: RX ant low band
: ons mar 10, 2021 0:32
I should have said the so the 4.5 dB noise figure is certainly not
unreasonable.
Sorry for the typo.
73,
Don (wd8dsb)
On Tue, Mar 9, 2021 at 6:20 PM Don Kirk <wd8dsb@gmail.com> wrote:
> A couple of weeks ago there were a lot of postings about my portable flag
> for radio direction finding (for tracking down RFI), and someone asked
> about the DX Engineering preamp that was designed for use with my portable
> flag and specifically what the noise figure was for this preamp. Tim
> (K3LR) said DX Engineering would measure it, and today he reported it
> measured 4.5 dB.
> Tim mentioned that there were trade offs in the design such as low current
> draw and high gain, so the 4.5 dB noise figure is certainly unreasonable.
> It really is the only preamp I now use with my portable flag, and very
> pleased with how it works.
> Just FYI,
> Don (wd8dsb)
> _________________
> Searchable Archives: http://www.contesting.com/_topband - Topband
> Reflector
_________________
Searchable Archives: http://www.contesting.com/_topband - Topband Reflector
Ja det er nok ikke en preamp der vil noget, jeg syndes at kan huske N4IS preamp med nf 0.5 dB
Re: RX ant low band
: man maj 24, 2021 4:07
Her
et indlæg til om RX Ant.
Due to the many inquiries about the HIZ receiving antenna, I have created a description of how this antenna is constructed with the components.Have fun buildingthis effective antenna.
"DL8LAS DR5X Andree Schanko skimmer" https://www.dl8las.com/7m-hiz-antena-construction
73 Andy DL8LAS
www.dl8las.com
_________________
Re: RX ant low band
: man okt 18, 2021 10:32
Re: RX ant low band
: fre jan 07, 2022 6:05
Det ser ud til at der en ny type RX Ant SAL 30
Fra Topband@contesting.com
It has been a long time since I looked at the SAL in which I modeled it
with the help of the designer of the SAL (KB7GF). The SAL is actually
different than the K9AY and other EWE types of RX antennas which have a
typical RDF value of around 7.8 because the SAL (Shared Apex Loop) antenna
actively uses two of its loops which are "in line" with each other for what
you might call the primary direction (direction in line with the loops),
and these two phased loops can provide an RDF value of around 9.2 depending
on the coupler locations. For the off axis directions (45 degrees to the
loops) I believe all 4 loops of the SAL are active (phased together) and
they provide a pattern more like what you would expect from the K9AY or
other EWEs with an RDF of approximately 7.8. Therefore in the 4 primary
directions of the SAL the SAL definitely has a better RDF than the K9AY or
other types of EWE receiving antennas.
When used "in line" the RDF of the SAL is around 9.2 as mentioned above
which is similar to what you would obtain using two phased verticals with
1/8 wavelength spacing.
Just FYI,
Don (wd8dsb)
I’m afraid your information is not accurate, SAL is the same as a K9AY, the two wires close to each other can be removed because they cancel each other. The remain wires works like two vertical in phase, as the same in any flag, loaded loop or pennant. The cardioid pattern is the same.
The is no implementation of two SAL in phase because it does not work, the phasing system is too complex to phase two SAL.
If you know the people that actually tested the antenna, you know that the claimed RDF was never achieved.
The RDF of the K9AY is the same of the SAL, the EZENEC does a horrible job with loops close to the ground.
Saying that, both antennas are excellent receiver antennas if you don’t have anything else.
73’s
JC
N4IS
Hi Jose,
To keep things simple, I say the K9AY is not like a pennant or flag since
it has been demonstrated by many people to be more ground dependent
(sometimes needing added ground radials). Under certain conditions the
K9AY should be identical to a Flag or Pennant but since ground radials have
been shown to drastically impact the K9AY performance depending on the
ground conditions this sure does not sound like this is always the case.
I won't debate the SAL (Shared Apex Loop), other than to say from a
construction standpoint it's definitely not the same as the K9AY or other
EWE type antenna (Flag, Pennants, etc.), and modeling the SAL definitely
yields a different pattern than a single pennant or flag when used in the
"in line direction" but as you said modeling does not always reflect
reality (your example was EZNEC not doing a good job with loops close to
ground). I have never used an SAL and therefore my statements are only
based on what modeling yields, but to say the SAL is the same as a K9AY is
hard to believe regardless if it performs better or worse than the K9AY,
just based on the design.
P.S. I believe there is a newer version of the SAL in which the two
halves of the SAL share the same center vertical conductor, but again I'm
not making any claims about the design. Also note I'm using 4NEC2 for my
modeling, not that it necessarily impacts my above statements.
73,
Don (wd8dsb)
https://www.youtube.com/watch?v=vm7w17D4pE4
Kan købes her: https://www.arraysolutions.com/as-sal-30-mk2-dx
Re: RX ant low band
: ons aug 24, 2022 15:18
Så der igen diskution om LB RX ant på topbank
Beverage vs phased array !
Igen for dem der lidt mere jord !
Hi Kenny,
Over the past 12 or more years I've conducted numerous comparisons of different receive antennas on the low bands. I'm fortunate to have enough land to lay all of them out with adequate spacing and perform A/B comparisons. I am in a rural area that is relatively quite although over those 12 years I have seen the noise floor gradually increase up to 5 dB in a couple of directions! A battle I continually fight!!
One thing I have emphasized over the years is the realized performance of any antenna will be different depending on the geographical location. Another point is most times radio amateurs have unrealistic expectations of what the performance of a specific antenna will be.
With that said, I have compared the antenna you are considering at your QTH here at W5ZN with a single Beverage that you currently use. I could not document any noticeable improvement between the two. That's not to say there wasn't any improvement, it just was not noticeable.
I begin to notice a difference when the RDF is increased by more than 1.5dB. I realize this is splitting hairs when we're claiming only a few tenths of a dB difference but that is based on my real world documented comparison.
The most significant improvement I have documented is moving from a Beverage to a phased vertical array. The Hi-Z and BSEF 8 vertical arrays are the top, with the HiZ outperforming the BSEF by just a tad due to the HiZ-8's improved F/B and F/S performance. The YCCC-9 is also an excellent performer. My measurements have also confirmed the modeling data for all of the arrays. I presented this data at Contest University - Dayton this year.
So my recommendation is to erect the new Beverage and give it a try. You may very well notice a improvement. If constructed correctly, it should be an improvement even if only a few tenths of a dB RDF and it won't be a loss !
73 Joel W5ZN
On 2022-08-23 14:07, Kenny Silverman wrote:
> In a rural area with no significant man made noise, if you redesign a
> beverage for better RDF when do you start to notice a difference?
> I’m considering upgrading my single EU beverage at 625’ (190m) to a
> pair in echelon where will each be 550’ (168m) with 20’ (6m) spacing
> . The increase in RDF is 0.8 dB - will it be noticeable?
> I realize if there’s noise in a direction where you reduce the energy
> you will better hear the difference , but my EU beverage is quiet.
> Though the F/B change will help with thunder storms off the back.
> Overall I tend to receive better than I transmit to EU.
> 73 , Kenny K2KW
> _________________
_________________
Re: RX ant low band
: tirs maj 23, 2023 23:35
Hej Så er der gang igen i diskution omkring small RX loops og preamp på
topband !
Many thanks for the replies (some direct) . . . it seems the LOG IS rubbish.
And Frank, considering what you say, my 6ft Vertical Loop in the Loft works
surprisingly well. It's obviously NOT near the ground, and there is mains
wiring running along the floor underneath it (to the lights in the ceiling
below).
Despite any shortcomings, having set the Preamp Gain so that a local signal
in the right direction is the same strength as on my Dipole, the noise is 6
- 10dB lower than on my Dipole. It also has a BIG null at right angles - a
local to the South of me is 30dB weaker on the Loop!
I can certainly tell that it works as a Vertical antenna, as not only the
strength but also the sound of signals changes a lot, especially if they are
around 1000 miles away (where normally a Vertical would be better).
Interestingly real DX signals (over 3000 miles) are rarely any stronger on
the Loop . . . which confirms my suspicion that DX on 160m is rarely Low
Angle! (based on reports I get from my Dipole Tx antenna too)
For anyone else who doesn't have room for a Beverage or even K9AY, here's
details again of my 160m Receiving Loop:
http://rogerkennedy.co.uk/g3yro/160mrxloop.htm
Roger G3YRO
-----Original Message-----
Sent: 23 May 2023 16:40
To: topband
Subject: Re: Topband: Loop on Ground receiving antenna.
Hi Roger,
Any 160 meter receiving antenna laying on conductive soil will have
extremely low RF output and you'll need at least 40 dB of preamp gain with
very low noise figure and you must take extreme measures to control common
mode currents. Antennas NEAR the ground perform dramatically better than
antennas ON the ground.
Vertically polarized small loops like your 6 foot loop must be installed
within about 7 feet of the ground, otherwise the two vertically polarized
deep nulls get washed out by horizontally polarized signals that are no
longer suppressed by ground proximity.
I hope you don't have a lot of wiring and other metallic structures in or
near your loft, otherwise your small loop doesn't have a prayer of working
at all. You also must take extreme measures to suppress common mode
currents when using a small loop.
What constraints must you take into consideration when selecting the
location for your receiving antennas?
Frank
W3LPL
----- Original Message -----
From: "Roger Kennedy" <roger@wessexproductions.co.uk>
To: "topband" <topband@contesting.com>
Sent: Tuesday, May 23, 2023 3:05:13 PM
Subject: Topband: Loop on Ground receiving antenna.
I just tried making a Loop on the Ground to see if it would be any lower
noise than my 6ft 160m Loop up in the loft.
I followed several people's suggested dimensions . . . so 15 feet each side,
feeding it in the middle of the side pointing West with a 450:50 ohm
transformer . . . And it's rubbish!
A local station (in the right direction) on my 6ft vertical loop in the loft
needs a 20dB preamp to bring him to the same level as on my Dipole (and the
noise is 6 to 10dB lower).
But on the LOG he was 30dB weaker, that's WITH the 20dB preamp! So the S/N
would be rubbish. Anyone else tried something similar on 160m?
Roger G3YRO
_________________
_________________
